time2roll
Feb 26, 2012Nomad
piano, I knew you would catch that :w
No the battery connections are not balanced. That is where the premade 4/0 wire landed. I don't intend to replace the cables to balance it. There might be a way to move the connections around but it is fine until these batteries get replaced. They have 6 years on them as is.
What I really should have done is moved the propane to the right and batteries to the left. Again, maybe when the batteries come out.
I don't plan to run the batteries down to test but as charged it took less than a minute to go 12.7 to 14.6v in the noon sun.
The whole thing might be more hobby than necessity. Reminds me I need to switch off the converter as it should no longer be needed.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
