CallThisCamping
Mar 07, 2012Explorer
I see you put your controller in a compartment. Have you noticed any heat build up in there? I had planned to do this as well and I have the same controller, but after reading the manual, I've been trying to come up with different solutions. The compartment solution would be far easier to install, and the inverter is already in there, close to the batteries. But I don't want thermal shutdowns.
Is your compartment open to the outside? If not, do you notice excessive heat from the controller heat-sync?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
