time2roll
Mar 08, 2012Nomad
Manual calls for 75 amp fuse to comply with NEC. (rating + 25%) So it was 70 or 80 and I prefer it to be a bit tight. Either is fine with #4 wire.
You are right there is no switch to the battery. Manual calls for a disconnect and I will remove the fuse when needed. The high voltage was a bigger concern.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
