watchthebox
Mar 08, 2012Explorer
CallThisCamping?! wrote:
Is it possible for you to draw a rough schematic of how exactly you wired everything?
You may also consider using switchable circuit breakers instead of fuses. They serve as circuit protection and disconnect switch. The ones I used are called Buss MRCB (manual reset circuit breaker). See picture. (Note, this picture was taken before I installed the cables from the solar charge controller and inverter to two circuit breakers at top of picture.)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
