cruz-in
Mar 08, 2012Explorer
watchthebox wrote:CallThisCamping?! wrote:
Is it possible for you to draw a rough schematic of how exactly you wired everything?
You may also consider using switchable circuit breakers instead of fuses. They serve as circuit protection and disconnect switch. The ones I used are called Buss MRCB (manual reset circuit breaker). See picture. (Note, this picture was taken before I installed the cables from the solar charge controller and inverter to two circuit breakers at top of picture.)
Very Nice! If you do not mind I have a few questions:
1) Why does your Solar Charge Controller output go to the "OEM Positive Load Mini Breaker Bank" vice directly to the battery?
2) Whick side of the "Master Battery Disconnect" is the Genny Positive connected to? The Battery or Inverter side?
3) I assume you would connect the negative for the charge controller and the solar panels to the negative buss bar?
4)I assume the Battery positive is still connected to the ""OEM Positive Load Mini Breaker Bank" along with the output of the Solar Charge controller? Just did not see this in your diagram.
Thanks and I apoliogize if these are dumb questions...I really admire your setup and just trying to understand it.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
