time2roll
Oct 17, 2013Nomad
To avoid my own personal confusion I adopted the boater's convention of B+ Red and B- Yellow. This avoids any issues with 120v hot, 12v hot (+), and 12v ground.
The 4/0 wire connects the battery direct to a Prosine 1800 in the side compartment. Large fuse is 250a class T. The smaller #4 connects the battery to the controller. Small fuse is a 70a Maxi in a Blue Sea holder.
Yes the pair of solar wires are wrapped in that corrugated plastic and come into the high voltage switch/fuse box on the right side of the picture. Then similar continues to the controller.
Green wire is chassis ground. Connects the metal box to the trailer frame.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
