daveyboy12
Oct 19, 2013Explorer
daveyboy12 wrote:
smkettner
In your picture, where is the lead in from the solar panels, is it the black line coming into the fuse box and then over to the charge controller? Then is the thick red wire the lead from the controller to the battery? What do the yellow and green wires lead to?
Why is there a thick red wire to the batteries and a 2nd thinner red wire?
Thanks,
Ok, thank you.
What size wire are you using from your panels to the fuse box? SO the thickest two cables (yellow & red) are the 4/0 those both go to your inverter? The smaller are 4 awg? those go between the charge controller and battery bank.
Thanks again for sharing your setup.. I am new and have some design ideas in my head, I just don't want to buy $2000 in stuff only then to determine I have the wrong stuff
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
