2000_American_E's avatar
Aug 01, 2020
7.5 Onan Diesel Generator
My Onan Generator is currently shutting down after running for a short time. I have had problems with this generator in our 2000 American Eagle since we purchased it in 2017. I had 210 hrs when we purchased it in 2017 and now 325 hrs. I had a very qualified technician check it out and replaced the control panel in 2017. I turn it on several times a year, load it up and it has been working most of the time. It seems to shut down when I need it. The code was 33 coolant high temp. I have changed thermostat, radiator cap, sensor, fuel filter, air filter. it is still shutting down with code 1 high temp. Any suggestions?
  • Have you pulled the coolant fill hose with the radiator cap out and extended it above the top of the generator and topped off the coolant?
  • It could very well be mineral deposits inside the cooling tubes of the radiator. That's what it was on mine (same model of generator on my 2003 Dutch Star). I removed the radiator and took it to a radiator shop for a complete cleaning procedure. The problem never came back.
  • How about the radiator or the fan? Does it overheat on no load?
  • 2000 American Eagle, can't help with the diesel Onan, we have a gas POS. Onan's are like an old woman, lot's of TLC!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
