dougrainer wrote:
IF you have truck running lights and just NO trailer running lights, you have the Trailer light fuse blown on your truck. Trucks and motorhomes built in the last 15 years, have a separate fuse for the truck lights and the tow plug lights. This prevents a tow vehicle short from taking out all the running lights. You even have a separate fuse for the Left and Right Turn signals on the tow plug. The usual location of the tow plug fuses is under the truck hood, not under the dash. Doug
Thanks, that is my next step tomorrow. I came home through south Texas with my emergency flashers on. As I said, all other lights worked so it wasn't an issue.
I will update tomorrow. Good info here.
