DiskDoctr
Mar 28, 2017Explorer
Huntindog wrote:
So I decided to install voltage regulators on the circuits that I wanted LEDS on. 3 circuits needed the mod. I got the regulators on ebay dirt cheap... Less than 5.00 apiece. They work great. They do have a fairly low amp rating of 3-5 amps, so all lights on the circuit need to be LEDS in order to stay under that spec.
As a side note: I only installed LEDS on high use lights. Bedrooms and bathrooms don't see much use from us, so I didn't bother with them.
I later switched my outside lights over to LEDs. I did not bother installing a regulator on that circuit... So far, so good.
I thought about that. I use them in Arduino projects, but the campers circuits are 15 amp and not separated from fans and such :E
They are all 15 amp- if I could find some reasonable 15 amp regulators, I'd install a couple of them.
...or, if I could find a decent (under $50?) regulator, I'd just install it on the convertor output to the distribution panel.
My unit is 55amp DC output, which includes charging. Surely wouldn't need more than that ;)
