Old-Biscuit
Nov 28, 2017Explorer III
Why not go with a digital mode vs those analog manual slider control types?
Digital heat only roughly $27 at that Canadian Tire website.
And more accurate temp control
Shouldn't need to add an ON/OFF switch. T-stat can be turned OFF
IS old t-stat not working.....or is issue with furnace?
Connecting the two wires together will make furnace run IF t-stat is bad.
If furnace does NOT run when the two wires are connected then Furnace has problem
