BFL13
Nov 28, 2017Explorer II
MrWizard wrote:
One question
Do you not have. Or not use the battery disconnect switch in the RV
Or just pull the heater fuse in the 12v fuses panel
No 12v disconnect, 12v fuses on fuse panel are not marked--I need to do a trial and error on those and mark them. (new to us rig) Good idea to use fuse if need be.
I often do work in the RV where I want the 12v on but it is colder than the thermostat goes down to, so I am looking at some on/off method if the thermostat does not have one.
EDIT--I don't mind if it stays on till temp is reached, but I want it to then stay off for a time until a lower temp is reached which triggers it to come back on, without getting too far down before coming back on. Something reasonable. What is a "short cycle" in that regard? Thanks.
