shastagary
Nov 29, 2017Explorer
take the two wires going to the furnace. touch them together. If the furnace starts to run, which i suspect it will, connect one wire to the W and one wire to the R on the thermostat.if he connects his 2 thermostat wires tougher the furnace will run that's what a thermostat does. it is a switch controlled by a temperature controlled relay circuit in the thermostat polarity does not matter home furnaces have ac control power to the thermostat. its not that complicated buy the thermostat and hook it up thousands already have.
