Rbertalotto's avatar
Rbertalotto
800w / 12v DC Water Pre-Heater???
Over at "Surplus Center" they have a 800w / 12V water heater for $20
Would this have value as a preheater at the sink or shower level to get hot water faster?
http://www.surpluscenter.com/Electrical/Miscellaneous-Electrical/Miscellaneous-Electrical/800-WATT-12-VDC-WATER-HEATER-11-3439.axd
12 VDC WATER HEATER
New, THERMO KING model 12-923 water heating assembly. Made as part of a winterization kit for heavy duty trucks. Includes mounting feet, connection box and hose barbs.
SPECIFICATIONS
Voltage 12 DC
Wattage 800
Ports 1 " NPT
Hose Size 3/4" ID
Size 16" x 4" x 4-1/2"
Shpg. 6 lbs.
  • Wow - 80amps at 12V...... how big are the cables connecting
    everything? and can your batteries supply that kind of current?
    G
  • 800 watts will heat water substantially. It will also draw 70 amps or so. How many batteries are you carrying?
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
