4xMike
May 31, 2015Explorer
Cleaned connectors and tired voltage at all appropriate areas. Tested gas valve. Ground is good. Discovered that if I disconnect from shore power the gas valve clicks on but there is no sparking. I checked voltage at the board for the ignition sparked as well as the gas valve and am getting +12vdc at both pins, so the board is good. Must be gas valve or igniter, but it would appear that the board is functioning properly
Note. I do not smell gas when the gas valve kicks on
Continuing to dig......
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
