dougrainer
Jul 09, 2017Nomad
jimwrye wrote:dougrainer wrote:
The usual cause is the system has scrambled. Disconnect 120 and the Large Battery cable to the inverter for 10 minutes. Reconnect the Battery cable and the apply 120. IF that does not stop the problem your Inverter is defective. NOT worth fixing a 22 years old Inverter. Doug
Had my hopes up, but to no avail. Looks like a new inverter. I agree that 22 years is old but then so is everything else, including it's owner.
Thanks for replying Doug.
Jim
You will need a NEW remote panel and communication cable also. The Xantrex Inverters for the past 10 years will not communicate with the older Remote panels. Doug
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
