Surviver76's avatar
Surviver76
96 Lance 3000: Systems Monitor - Battery Monitor Questions?
Hi Guys, I have what seems an odd occurrence I need guidance on soon.
A short or some sort of failure is interrupting the charge signal to my AGM 115ah battery so it gets less & less which I know is damaging to the battery. First, I am in Yuma so getting lots of sun on my solar. So far I have no battery monitor and realize my shortcomings for this lack.
Here is a brief description of my current system. 3 Siemens 50W panels on the roof, ASC Charge Controller, 600W Inverter & FullRiver 12V 115ah AGM Battery. I purchased this battery last week believing my old one was failing and it seems that the old batt may have been ok and my system was where the failure was occurring.
I think the problem may be in the cheesy Lance issue "Systems Monitor" on the wall of the TC. A few weeks ago we had a hot spell and my systems mon showed batt all the way up to the green. Then, with the same basic weather pattern, it went down to one red light at the bottom and the pump was laboring, battery very low. I then thought the problem was the batt. After installing a new batt the same thing is happening and pretty sure I didn't need that new battery after all.
My question is if I install a good Trimetric Batt Mon, how do I deal with the Systems Monitor on the wall? Can I just disconnect it?
If so, how would I do that and I'm thinking the Trimetric could tap into the wiring near my existing charge controller. Also what size shunt should I install and does that go out in the battery bay?
Any help appreciated...
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
