BB_TX
Aug 22, 2014Nomad
I don't think I would try it. The 30 amp and the 15/20 amp outlets use a common hot line and a common neutral. Adding the generator into the mix introduces a separate hot that is not in sync with the pedastal hot and a neutral that is not common to the pedastal neutral. You would be tying the two neutrals together in the "cheater". I honestly can't say what the result would be, but I would be concerned about the result.
