the_bear_II
Aug 22, 2014Explorer
I'm guessing you need more than 30 amps because you want to run a bunch of stuff at the same time including your air conditioner(s) ?
The 30 amps will supply most needs including running one A/C but when you need to use a second heavy draw item like the microwave you may need to shut off the A/C.
What you are proposing may work but is it worth taking a chance on ruining a $1800 generator or damaging the RV electrical ?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
