wtfjr's avatar
wtfjr
A "cheater plug" in along with a Honda EU 2000i ????
Hi All
We have an electrical question as follows--
For our first time we plan to use a cheater plug at Sebastian State Park where all that is offered is 30 amp service. One arm of this cheater plug will plug into the 30 amp side of the shore power station & the other arm from this "cheater plug" will plug into the 15 amp side of the shore power station giving us up to 45 amp service into our power line. The only potential problem is that if the 15 amp side of the shore power station is GFI protected, this Cheater plug will not work, as the GFI breaker will trip to off.
Our question is, if this 15 amp plug in can not be used by us due to the GFI breaker, can we use our Honda Generator EU 2000i to plug into as an alternative to the 15 amp power & not negatively affect anything in the coaches electrical system ?
We feel the Honda will run more quietly & use less gas than our Onan 7.7
We'd really appreciate any comments or suggestions here. Thanks !!
PS; we are aware that with 30 amps you only run one a/c & nothing else like a microwave, coffee pot etc.
PSS; what is the difference between running the onboard Onan 7.7 & running the Honda instead ?
  • Better to just use the regular 30a adapter that feeds both sides.
    Watch your voltage but two air conditioners may work. Keep the fridge and water heat on propane only.
  • wtfjr wrote:
    ....we are aware that with 30 amps you only run one a/c & nothing else like a microwave, coffee pot etc.
    We have 30A service and have no problem running either the microwave or coffee pot with the a/c running. I keep the fridge on electric but the HW heater on gas.
    What you are proposing sounds like a dangerous mixture....
    Also interesting commentary that we can't live with a mere 30a when "camping"....
    If you really need full 50a, then run the Onan, that's what it's there for. Although not sure your neighbors will appreciate that.
  • Rent two sites, and use the 30a outlet from each ... maybe sites that are back to back rather than side to side so you don't need as much extension cord.
    Running a generator at a state park that provides electrical hookups sounds like a big faux pas to me... plus several of the Florida State Parks website have this listed in the rules:
    "Generators are not allowed in the campsites."
    Interesting phrasing, giving the rangers a lot of enforcement leeway - a strict interpretation could be that mere possession of a generator is against the law whether it's operating or not.
  • The below is a suggestion received & I wanted to hear what the board thought of it ??????
    ""On your question on how to hook up your RV using your RV adapter. If it is the type of adapter with two plugs, one 30 amp and the other 15 amp, you may be able to get it to work with the GFI outlet at the campground. Remove the ground from the 15 amp plug of the adapter by breaking off the ground prong of the 15 amp plug of the adapter. To use, plug the 30 amp plug into the campground 30 amp outlet, and plug the 15 amp plug of the adapter into the 15 amp GFI outlet of the campground. Make sure the 15 amp plug is positioned as if it still had the ground pin, so the polarity is correct. This is safe as your RV will still have a ground connection via the 30 amp plug.
    That should work. Just so the ground wire of the 15 amp adapter plug is not connected to the GFI outlet ground. Make sure to maintain the polarity of the 15 amp plug so the hot and common wires are connected as if the ground pin was there. As long as there is no other problem, this should work.
    What happens: If the GFI outlet senses current through the ground terminal it will trip. Having the 30 amp and 15 amp plug connected to the camp's 30 and 15 amp outlets' ground, (via the adapter) the two ground terminals of the camp's outlets will be connected together. There will always be a small current flow from one outlet ground to the other, and the 15 amp GFI outlet will trip. Removing the ground connection will break the contact, and no current will flow from one outlet to the other.""
  • I don't think your neighbors would like to hear the generator running even if the state campground allowed them to be used.
  • Besides if the Honda is powering the side with air conditioning... good chance you will be feeling the heat.
  • wtfjr wrote:
    The below is a suggestion received & I wanted to hear what the board thought of it?
    "...Remove the ground from the 15 amp plug of the adapter by breaking off the ground prong of the 15 amp plug of the adapter...."
    Removing the ground is a stupid (dangerous) suggestion and won't work anyhow. The GFCI monitors the current on the hot and neutral, not the ground.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Actually .... Removing the ground pin on the 15 amp plug (If using the Honda) would make no difference as I believe that inside the Honda that pin is N/C. (it is how Id make it)
    If plugged into the park's 20 amp outlet: eemerphile1 is correct, it will not work. For reasons he explained and I also have stated in many threads.
    Incorrect! The GFCI outlet monitors current between hot and neutral. If more is going out on the hot than is coming back on the neutral it assume the current is flowing through something (someone) else and trips.
    With a cheater type setup it is possible for current from the 15a plug to return on the 30a neutral which is what causes the trip. Has nothing to do with the ground plug.
    Seriously, what is big deal about "surviving" on 30 amps? maybe you need to find a different CG?
    Sounds great, BUT my wife likes to fish here better then anywhere else, They only offer 30 amp service on a very good day.
    What's a hubby to do ??
