Tamnative's avatar
Tamnative
A different solar question
I have a friend with a class"c" RV and he would like solar to charge not only the coach batteries but the engine start battery also. Is there a solar charger made that can do this.
The charger I have has 2 terminals 1 for battery charge and 1 for load. It is my understanding that the load should only be used for lights or heating type elements and not as a second charge terminal. Has anyone done this or heard of a charge controller that will do this?
  • I just have a switch on the dash that connects the positives of the chassis and the house batts together whenever it needs charging. Sometimes you can get what you don't pay for.
  • The Blue Sky SB3024 also has a 2 amp auxillary output to charge a chassis battery.
  • A good bi-directional (BIRD) solenoid makes good sense. And they are a lot more sensible choice than specific-purpose gizmos.
  • +1 for Trik-L-Start with or without solar.
    Really not a new or different question at all.
  • My Blue Sky 3000i solar charge controller has this feature. In my opinion this is one of the top notch controllers to fit my 30A needs. It has a 2A output dedicated for just maintaining the engine battery. Perfect! No need for any secondary trickle chargers or the like... the solar charger does it all.
  • Ray & June wrote:
    Used the Trik-L-Start for years. Great product.
    Ya what he said :B
  • Thanks Snowman9000 that is what I was looking for and I will pass this along.
    Heck after looking at the TRIK-L-START I think I am going to do this also !!
  • Moved from TC Forum to the Tech Issues Forum.
    Wayne
    Moderator
  • There are two ways to skin this cat. First of all, yes, there are controllers that are set up to charge a coach battery and the chassis battery. Here are two:
    Morningstar Sunsaver Duo
    Renogy Duo
    The other way is to have a device that diverts some charging to the chassis battery. Some RVs have this built into the battery disconnect system. His Class C might already have one. If not, there is a simple add-on:
    Trik-L-Start
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
