2oldman
Jul 31, 2022Explorer II
Qwazert wrote:You have these panels hooked up AND connected to shore? I guess the simplest answer would be your 2-3 amps is all the batteries are asking for, and adding another panel doesn't make any difference.
Does the controller sense that less is required because the batteries are fully charged (still connected to shore power)?
Turn shore off, put some load on the batteries, drain them a bit, then try again.
