CA_Traveler
Aug 01, 2022Explorer III
Qwazert wrote:In fact the amps would be the lower Imp panel.
As I understand things, connecting them in series will not be much of a benefit, since I need more charging CURRENT, as opposed to higher voltage.
Serial panels with a MPPT controller can be a better option depending upon a number of parameters. MPPT converts the higher voltage power to the battery voltage and increased amps. Basically the OP would get about the same amount of battery V and A for charging as the PWM controller with parallel panels.
