BFL13
Aug 20, 2014Explorer II
Old-Biscuit wrote:
Good for you........
Item #2
Material doesn't move in slot on side of trailer due to the screws at each edge so I just shifted the awning material in slot on roller to re-align.....then I installed a 1/4" screw in roller slot at edges of material.
Haven't had to re-align since
Thanks, I will check the roller slot and block it too if it isn't. If it is able to shift there then the problem could return. Unless the awning stretched, that would be how it got off kilter in the first place with the top held in place.
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Jul 20, 2015
