Gjac
Aug 20, 2014Explorer III
My stove is probably older as I have the push button with the spark in the middle with three tubes going out from the middle. What I have noticed is when I perk coffee it sometimes boils over and gets under the spark bracket in the middle. I have had to remove the sht mtl bracket and clean under the there to get the spark working again. For the day/night shade my string broke also I tied it back with a square knot and glued the eye back with super glue. Also learned that if you put too many turns on the string to keep the shade from vibrating down that will cause the string to break also.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
