Bud99
Jul 22, 2014Explorer
A G M Batteries
Are A G M Batteries worth the extra money? Do they outlast wetcell Batteries or am I just as well off buying 2 wet cell batteries for use in my 5th wheel?
Thanks,
Bud99
Thanks,
Bud99
Thanks,
Bud99
Bill.Satellite wrote:A little off topic but how are those UB's holding up? I was considering those myself a few years ago.
Yes, the UB's are Chinese so if that's not your thing then buy the Lifelines. For me, the difference between $600 per battery and $300 per battery made me blind to the certificate of origin!
pigman1 wrote:You got that right. I got pretty weary of the maintenance of watering. It takes some big pockets to buy your way out of it, but it's really nice once you do.
The big selling point for me is no need to add water, and absolutely no corrosion....EVER.
BFL13 wrote:
It is a specialty situational thing whether the AGMs would be worth it to YOU.
Besides the situation where you cannot get at your batteries for hydrometer and water level checks easily, making AGMs better, the other thing that really came to light in previous threads here was (as mentioned above) little voltage drop under heavy load.
kccwoodworks wrote:AGM's DO gas if you overcharge them. And "overcharging" can be using too high a float voltage in hot weather. Another member here confirmed that in his testing (HiTech). You don't want AGM's to outgas. Keep your voltages close to manufacturers recommendations and use temperature compensation. It seems a lot of people here use solar in conjunction with AGM's so my guess is they're using temp compensation.
What no one has mentioned yet is AGM's don't gas. They don't need to be vented therefore are safer. The only place for batteries in my van is inside where a wet cell would be dangerous.
