- pianotunaNomad IIIHi MrWizard,
No, for this particular iteration of grid tied no external power (from shore power) is required for the unit to continue to produce power. The reason for that is that the inverter is a hybrid model. It is designed to continue to work when the grid goes down. - valhalla360NavigatorSo the charge controller is integrated in with the inverter.
I really don't see much use in an RV application. - GordonThreeExplorer
MrWizard wrote:
take the output from the micro inverter, and connect to the rv house 120v and power the converter ?
the trouble with grid tie micro inverter is the same as any other Grid tie
it must be connected to 120v supply and sync to it
no exterior 120v,it shuts OFF, no output
How would that be helpful if you're dry camping then? Run a generator to kick the grid tie on?
I'm completely lost on this subject. Why grid tie, why microinverter for an RV? - MrWizardModeratortake the output from the micro inverter, and connect to the rv house 120v and power the converter ?
no exterior 120v,it shuts OFF, no output - GordonThreeExplorerI give up then. Just wanted to know how you charge batteries with a microinverter without backfeeding shore power, but I guess that's a secret.
- pianotunaNomad IIIGordonThree,
I think it is on the supply side of the inverter. - GordonThreeExplorerSo the PV is attached on the house side of the inverter rather than the shore side?
- road-runnerExplorer IIIDuplicate posted by mistake.
- road-runnerExplorer IIIThe charge controller is eliminated as a separate module. Its function remains, moved to the main inverter and microinverters. This is a nice technology jump from previous AC coupled systems, where there had to be added hardware to disconnect the microinverters or kick in a diversion load when the battery was charged and there was excess solar power. It looks like now the main inverter can tell the microinverters to throttle their output as needed. Pretty clever about adjusting the frequency. Some older systems changed the frequency to kick the microinverters totally off. Using the frequency for throttling is new (to me, anyway). Load support is a totally different feature.
- GordonThreeExplorerSo it can use the 240v PV array to charge batteries while running load support on shore power?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
