- AlmotExplorer III
Noel wrote:
CRC says "Stor & Go" is better than the others.
Have not seen this before. Any one used this ?
Thanks
Like Dawg said - it's a religious thing :)... Pick whatever you believe in. I used both Seafoam and Stabil for storing my ancient carburetor truck for a 10-12 months. With 30-40% full tank. Sometimes with the same gas for 2 years, sometimes replacing old gas and 'foam after a year, sometimes adding fresh gas to partially used old gas (and then adding more 'foam too). Didn't notice any difference. Never let it sit without movement for more than a year. Never keep old gas for more than 2 years without at least partially diluting it with a fresh gas.
Rust and other climate-related deterioration was giving me more pain.
In little outboard motor I just drain the carb dry when storing more than 6 months. - AtleeExplorer IIDuring camping and football tailgating season, I don't use any stabilizer, but when I do use a stabilizer, I use Seafoam.
Seriously, during the period I know I will be using the generators a lot, which means using the gas in the gas cans, I don't use any stabilizer. I go through a lot of gallons.
But when I've shut down for the year, I will then put Seafoam in all the can containers and the generator tanks. - HondavalkExplorer IIAnother Star-Tron fan here.
- dalejExplorer
ctilsie242 wrote:
I've been using Star-Tron myself, and it doesn't discolor or darken, from what I've seen. It also has worked well.
Same here good results in Motorcycles and boats. - MEXICOWANDERERExplorerThey're trying but Pemex insists on a max of 5% and the USA refineries are not ready to custom blend because the fuel comes from multiple US and Japanese refineries.
The price for Magna, which is regular is around $3.35 gallon. In the border area and all of the northern of the 2 baja california states all fuel comes from the USA or Japan. - SidecarFlipExplorer IIIDoes Pemex contain alcohol?
- MEXICOWANDERERExplorerNaptha. White gas. It is incapable of decomposing in the presence of O2
- Itinerant1ExplorerStartron here also seems to do the job.
- ctilsie242Explorer III've been using Star-Tron myself, and it doesn't discolor or darken, from what I've seen. It also has worked well.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 09, 2026
