Naio's avatar
Naio
Explorer II
Mar 03, 2020
A shunt on chassis motor?
Yep it's me again, with another harebrained scheme :-).
My current van doesn't have an isolator setup. For an upcoming trip, I'd like to be able to run my mini freezer while driving. I don't want to do a whole isolator solenoid deal at this time.
It seems like the simplest way might be to hook up my inverter to the chassis battery with an Anderson connector, and unplug it or shut off the inverter when stopped.
But how would I connect to the chassis battery without interfering with the starter/battery clamps? I'm too chicken to use jumper cables :-). Is there some type of shunt that does this job?
  • A shunt is not the device you're looking for.
    But the only way I know to do it is the right way, with heavy cables directly to the battery.
