MEXICOWANDERER
Dec 12, 2018Explorer
Oooooo I was actually involved in a college class project involving the Starfish Prime phenomenon, Hawaii.
The MIS-conclusion of evidence came about because the MERCURY VAPOR street lamps use high voltage transformers and those street lamp ballast boxes were badly sealed. High humidity high temperature salt laden air.
With my own eyeballs I examined one of the ballasts. It was a ruin of corrosion including rust drippings onto transformers, green electrical terminations and finally constant failures according to the Honolulu city maintenance records.
Microwave and radio communications were interrupted but to a lesser degree today's communications are interrupted by extraterrestrial solar flares.
My doctorate was planned around the creation of a holographic projection of an electromagnetic field. To an intensity of many x factors as measured in Teslas.
Teslas are the measurement used in MRI full body scans. How strong? A Brazilian janitor was killed when he walked into an unoccupied MRI room in Sao Paulo Brazil with a 20 lb fire extinguisher. The machine was on and it magnetized the fire extinguisher and pulled him 3 meters across the floor and then crushed the extinguisher against his crest preventing him from breathing. This is to the tens more power EMF than the Carrington Event. And guess what I brought a cheap watch into the the MRI room which is heavily shielded and laid it on a water basket. A five dollar watch. When my spine was finished I picked up a perfectly fine LCD watch and slipped it onto my wrist.
Never rely on politically charged recollections of historical events.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
