cannesdo's avatar
cannesdo
Aaaaa...Now the main A/C is out....
I have two A/Cs...the one in the living room (Duo-Therm -- ducted) turns completely on and then completely off throughout the day. The bedroom A/C (Mach 8) sounds like it's on all the time but the compressor cycles on and off, you can hear it starting and stopping.
Well, the living room A/C just made that sound but it's not a sound it's ever made, and after that it was just blowing like a fan even though it was set on A/C. The air is not cold. What are the possible causes? Does the compressor sometimes just die? It's 15 years old. Any suggestions about what to check and how would be appreciated. I'm pretty mechanical and don't want to pay for any more labor than I have to. I've replaced the motor in my furnace.
It was just running on low when it happened. Sort of a clicking sound, like the other one makes when it's cool enough inside and the thermostat tells the compressor to shut off. But I knew immediately it's a sound the main ducted A/C doesn't ever make and shouldn't be making.
Thanks!
Ok, wait...now it's blowing cold air again. For about 10 min. it wasn't.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
