wintersun
May 09, 2014Explorer II
Water supply lines, hot and cold, are not going to be PVC or ABS in any building or RV. Instead a flexible line is used and unfortunately this practice has extended to residential construction with PEX where it is a poor substitute for copper piping. Waste lines outside the living space are always done with ABS pipe where the installation is a permanent one and not easily repaired or replaced.
I have a sprinkler system at my house for which I naturally used PVC. All the exposed pipe has become brittle in less than a year's time. I would not want PV used in a RV for pressure lines.
PVC also loses strength with temperature. A pipe that has a PSI burst strength of 450 PSI at 73 F (temp used for standards) will have a pressure rating of 337 PSI at 100 F.
PCV also expands with temperature and a 100' length can expand 4 inches with 140 degree water inside (or less with outside air temps over 100 F) and with an RV a 20' length could still expand an inch and cause a problem.
With an RV the manufacturers err on the safe side to avoid plumbing problems that could be prohibitively expensive to repair with the very limited access with most RV's.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
