Bobbo
Nov 13, 2022Explorer III
SJ-Chris wrote:
This is one of the main things I'm trying to understand about the cooling unit operation while out of level. Assume for example the RV is parked on a steep driveway with the refrigerator on. What happens if the refrigerator is out of level and starting to overheat and the refrigerant cannot flow where it needs to flow. Then a thermostat cuts off the refrigerator power when the boiler temp hits 205*C and then turns it back on when it cools to 170*C and it just oscillates between 170*C and 205*C. Does any damage occur if left in this oscillating state for a few hours or even days? Would the refrigerant cool and harden and cause some incremental damage?
-Chris
Yes. The problem is when the refrigerator is running, it vaporizes the ammonia solution. That vapor then goes into the piping where being off level causes some of it to retain and solidify. It being subject to occasional shut offs doesn't prevent that. I am unsure if occasional shut downs would slow down the process because it is running less, or speed up the process because it has more cooling off periods for the ammonia to precipitate. It would definitely reduce the cooling efficiency inside the refrigerator.
I believe the only way to assuage your fear is to replace it with a compressor refrigerator.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
