dougrainer
Nov 15, 2022Nomad
S-J-Chris. Are you an Engineer? Also, when commenting on temps in the USA, use Fahrenheit, not Celsius. 99% of people do not want to figure out C to F. That said, the normal operating range is about 350 to 400 degrees F. The TRIP temp of the Norcold recall box is about 750 degrees. The trip temp of the Norcold and Dometic temp disc is about 800 degrees.
As to off level. People forget all those times when traveling they stopped for a few hours to sight see or eat and those times start to add up. Rarely when pulling over will you be level for safe operation. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
