otrfun
Nov 16, 2022Explorer II
SJ-Chris wrote:The Fridge Defend high-temp cut-off is adjustable (at least on v4 and v5). Instructions how to adjust it can be downloaded at the FD website.
. . . I would guess the Fridge Defend is designed such that you can adjust those temperature settings for detecting high temp . . .
-Chris
The FD logs the maximum boiler temp and number of times the high-temp cut-off has activated (since the last user reset). The boiler temps on our Dometic DM2663 typically hover between 185-190c/365f-374f (on propane, 120vac, and 12vdc). After a year or so of travel with zero effort to make sure our truck camper was level, the FD logged a max boiler temp of 207c/405f (we reset it). Just to be on the safe side we also reset/lowered the factory default high temp cut-off from 217c/423f to 202c/396f. After another two years of travel, max boiler temp has only risen as high as 197c/387f. Lastly, just to make sure all was well after all these resets, we manually heated the FD boiler sensor above the high-temp cut-off. The FD cut-off 12vdc power to the fridge control board and logged it.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
