grizzzman wrote:
VintageRacer wrote:
First question is why look up the specs if you are going to second guess them? I use right around that voltage. Absorbtion is a higher voltage but with a continually dropping current that goes right down to almost nothing at the end, then you get the maintenance or float charge. Your numbers look perfect to me.
Because Interstate are idiots at getting correct information to there customers. The batteries are made in Mexico in a factory that US battery built. US battery charging specs
I love it!
Car GPS instructs clearly to make a LEFT RIGHT HERE
Right up a freeway off-ramp
Mustn't question instructions...
