jrclap63's avatar
jrclap63
AC air Flow not equal?
Hello. I have a Citation 27J with a Dou-Therm roof mounted AC unit with 4 vents in the ceiling. The 2 that go to the rear bathroom and rear living area have the most air flow and the bathroom gets like a freeze. Meanwhile the one to the front bedroom has hardly any air coming out of it. If closed the back 2 vents as much as I can, but it doesn't seem to help. Any suggestions before I start tearing things apart?
  • Had the same freezing bathroom issues with ours. I took a pice of thin cardboard, cut out a small triangle, about 1/4 of the opening, and put it under the A/C outlet cover. Problem solved.
  • I recently had one with a similar issue.
    I remove the unit and found the rubber roof hanging down in front of the duct to the bedroom. Taped everything down with aluminum duct tape. Fix the problem.
    I had to remove the unit on the roof to get to the problem to correct it. Remember, it's 120 Vac. So unplug it.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
