moresmokeExplorerJul 12, 2015A/C and an inverterHow big of an inverter would be required to start a 15k btu a/c? I'm not interested in the 12v supply debate, just need to know how many Watts to start the unit. 2500 continuous/5000 surge?
JiminDenverExplorer IIJul 12, 2015heh heh hehI had a 3000/6000w psw inverter that lasted until I started a 5000 BTU air conditioner once. Now it wont hold voltage and isn't worth fixing.A 24v inverter would be better IF you systems can be set up for it, including charging.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
Related ContentInverter Bad?Truck Camper A/C instalationInverter installRunning A/C over draws the batteries causing inverter alarmA/C
