Jasonbeckett's avatar
Jasonbeckett
A/C and heater problem
I just recently purchased a 2000 coachman leprechaun 313QB it has a newer dometic roof unit model is I believe R410A. It has the digital thermostat and the factory heater unit.. Well my problem is when I turn the heat on the a/c comes on to and blows ice cold while the heater is nice and hot.. How do I fix the a/c from coming on when my heater is on? I can do it myself if it's not to complicated. I was told about a aux setting in the thermostat but never seen that on mine... Any help is greatly appreciated thank you
  • Jasonbeckett wrote:
    That worked. Thank you.. I'm new to owning a RV still learning about them... Thank you again...
    IF you have the small square Dometic tstat. IF the fan is on Lo or Hi, ONLY THE AC FAN RUNS AND NOT THE COMPRESSOR. So, the roof AC will NOT blow cold air, only the inside existing air temp will be blown. Doug
  • That worked. Thank you.. I'm new to owning a RV still learning about them... Thank you again...
  • set the fan speed to "auto" if you do not want the ac fan to run when the furnace comes on. use + or - to change when in fan mode.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
