I have a 2000 Duo Therm brisk air ac unit and I need to replace the motor and blower wheel. How do I get the blower out of the blower housing? Is there a way to remove the housing?
If you must change the inside blower squirrel cage, you must move the evaporator out of the way- just be careful to not kink the copper lines. Also make note of the screws as you remove them- I don't think there are any short screws on a Brisk Air, but sometimes there will be one, and it has to go back in the original hole (because it was short for a reason).
