mileshuffExplorerJul 03, 2018A/C breaker trips whenever ambient temp is high?The A/C on my 5'er will trip it's breaker whenever ambient outside temp is high, 95F+. It will run only 10 minutes or so before tripping. If outside temp is lower than that it will run without issue...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
Related ContentAmbient Temp Sensor TroubleshootingGFI BreakerHow do you measure the ambient temperature?Fridge temperature depends on ambientall breakers blowing
