time2roll
Apr 27, 2014Nomad
travelrn2013 wrote:Anything over 108 is solid good, no worries. The issue is not voltage.
With ac on and two computers plus tv, couple of lights and frig the reading is 118.6 and 119.4 Will be doing a thorough cleaning of ac unit tomorrow morning.
The issue is other items drawing power since it is the 30a main that trips. To stay cool put your fridge and water on propane. You can even turn off all breakers and enjoy the cool as you sleep. Should be able to run off battery power for the night.
Speaking of batteries.... Have you checked your battery for excessive heat or boiling? The converter can draw a lot of power if the battery is shorted.
Also check for heat on the body of the breaker itself. If it is a double breaker they tend to build some heat with so much power feeding in through the main and directly out through the air conditioner. The shared heat makes the breaker more sensitive.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
