Is there a way to check the voltage at the compressor to tell if it's working right. It's a 2015 with 15k ducted. I am in Houston TX but it seems to not keep up during the day. Where do I start first?...
Take a thermometer and check the temperature at the return and discharge ducts if you have about 17 degrees F difference then you AC is working maxed out.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
