eocamper's avatar
eocamper
A/C Collingwood issue
The last 2 outings it took some time for cold air to come out of the vents.
The 1st time it happened it was around 30 minutes before I felt cold air.
Last weekend, I turned it on left and returned an hour later to a warm trailer and warm air coming from the vents.
What I did to get it to work was lowered the thermostat all the way. Immediately I heard the compressor kick on.
I left it that way all day (Forgot about it) and the thing froze.
I raised the temp. some and it was fine all weekend.
What do you folks think I should be looking at. Relay maybe?
  • Are there any air filters that may be plugged up. If seen a couple of AC systems freeze up because of inadequate air flow due to very dirty air filters.
    Ken
  • I would look at possible thermostat problem first. Is it analog or digital? An analog thermostat can develop a bad mercury switch over time which might explain the need to lower it all the way to get it to come on.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
