sayoung
Feb 08, 2022Explorer
3 tons wrote:sayoung wrote:3 tons wrote:
As I recall you should not be using the start run capacitor with the soft start…
3 tons
The RUN capacitor stays or it won't start. I looked at a few soft start install schematics and all unwired the start cap /pt cr.
I respectfully disagree…
3 tons
Single phase semi-hermetic,Rotary, or scroll compressor will not start without a RUN capacitor but it will run after achieveing about 70% operating RPM without it. A Start Capacitor is a booster and only stays in the circuit briefly or it will be damaged. Most all RV AC's use a capillary tube metering device and should never need any hard start capacitor type accessories if getting proper voltage/current
OP probably unhooked the incorrect lead from RUN capacitor
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
