jkwilson
Feb 09, 2022Explorer III
Going back to an earlier post you mention a toaster oven “ramping up” its power use. That doesn’t make sense. A resistive device will instantly go to full power and then actually fall just a bit as the elements heat. The ramping effect you are seeing may be a problem with your inverter or battery system limiting power on initial demand and could be the source of the air conditioner problem as well.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
