down_home
Aug 15, 2021Explorer II
Check out and possibly clean the ac unit on the roof. If it still won't do the job higher output units are available. I don't know whether you are 30 amp or 50 amp. Competent Technicians, Mobile Tech generally better can advise on this. Some Towables 50 amp have provision, or did, such as our 2002 Holiday Rambler Fifth Wheel for two a/cs but came wit only one, wires everything and framing were there just covered by ceiling and roofing. Wee upgraded one heat pump that was acting up to, nearly double output,in Kingman, Az. Turned the RV into a meat locker. maintained 72 degrees in 103 to 113 degrees or thereabouts...and heat side kept it warm down to below freezing...but furnaces did kick in once or twice.
