dougrainer
Aug 16, 2021Nomad
A 32 foot RV with a slide will still not cool adequately in higher temps with a 15k btu AC unit. It will do better, but not get below 75 degrees in hot climates. You need a extra 13.5 btu AC unit installed. If you only have 30 amp service, you will have to add a 2nd 30 amp cord and 20 amp breaker box to run that 2nd AC. If you have 50 amp service you can add the 2nd AC a lot easier. Doug
