down_home
Aug 16, 2021Explorer II
Bob it seems you are just trying to get by, and you will never get cool, in high heat.
$600.00 for larger unit will help changing to 50Amp is not that hard if you have done it. Total $1000.00-$1500.000I think for an additional unit and conversion to 50 amp. I don't know anyone where you are at but in Kingman, Az I do. I and others sent him so much business, it might take a bit for an appointment.
Like I said our Mh was 50 amp of course, 39 ft two units and with installation of new higher output unit in front location, in Kingman,Az heat, we sat there for a year on a family mission with temps after the replacement of 72 degrees in the heat of 103 to 113 on a few occasions in 2019-2020. Bob I do not BS!
On edit correct the math...
A higher output unit that won't overload your 30 amp circuit with every thing else running will help and more than you think.
Gog to 50 am means a new 50amp controller/charger/converter.Everything can be wired, in all probability to one 50 am leg, a second heat pump/ac to the other leg. Might mean snaking wiring from charger converter to second a/c. and of course a new 50 amp cord from control center/charger/converter and new 50 amp outside cord.
Two ways to fix a problem, yourself or an expert and you pay for it to be done.
You want cool/cold air in the southwest either this or go up high to Flagstaff and north.
You have a fine a really nice unit but it's a/c or heat pump was not designed with the southwest deserts in mind!
