doughere
Mar 19, 2016Explorer
I would check the sink's air vent. This device is designed to allow air into the drain line (grey tanks smell just as bad as black tanks). If the vent flap is bad, it will allow air to exit the drain line into the unit. The vent just unscrews to remove it.
I once had a problem similar; it turned out the tank vent line through the roof wasn't well sealed, and stinky air was entering through the cracks. Stuffing fiberglass in the cracks solved that problem.
Doug
Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
